13 Elden Ring Runes Farming Tricks That Save Time
Verfasst: Sa 26. Jul 2025, 09:49
von ElmNomad
Farming runes efficiently in Elden Ring can be the difference between barely scraping by and steamrolling your next boss fight. If you're deep into a playthrough or starting fresh with a new build, knowing where and how to farm can save hours of grinding. After dozens of hours across multiple characters, I’ve put together 13 tried-and-true rune farming tricks that have consistently paid off for me — no exploits, no mods, just practical, time-saving methods.
1. Start at the Best Early-Game Farming Zone: Gatefront Ruins
If you’re just beginning, the Gatefront Ruins are perfect. Enemies here drop enough runes to give your early leveling a jumpstart. Stick to mounted combat and quick strikes to clear the area fast.
2. Utilize the Gold-Pickled Fowl Foot
This consumable boosts rune acquisition by 30% for a limited time. Always use it before clearing a known farming area. Stack it with other boosts for even better returns.
3. Take Advantage of the Mohgwyn Palace Farm
Unlocking Mohgwyn Palace early through Varre’s quest or a portal makes it one of the best places to farm runes mid- to late-game. Use ranged attacks from the cliff to snipe Albinaurics or clear the bloody swamp on foot for maximum rewards.
4. Use the Sacred Relic Sword’s Wave of Gold
Post-game players can farm extremely fast using the Sacred Relic Sword’s weapon skill. Pair it with Mohgwyn Palace and clear entire packs in seconds. This is hands down one of the most efficient rune farming combos available.
5. Equip Rune-Boosting Talismans
Talismans like the Gold Scarab significantly boost rune gains. Found in the Abandoned Cave, it's worth the effort to obtain and use whenever farming. Combine this with consumables to further maximize efficiency.
6. Clear Fort Faroth’s Bat Nest Repeatedly
This location in Caelid is great for mid-game characters. The bats here are relatively weak and drop a good number of runes. A solid AoE weapon can clear the area in under a minute.
7. Reset World States Using Site of Grace
Don’t forget to rest at a nearby Site of Grace after each farming loop. This resets enemy spawns, letting you maintain a fast rhythm without downtime.
8. Chain Kill Nights Cavalry for Big Rewards
Hunting Night’s Cavalry at different locations yields massive rune rewards and unlocks some excellent gear. They respawn each night, making them a viable target for consistent farming.
9. Dual-Wield for Faster Clears
If your build allows it, dual-wielding strong weapons like curved swords or katanas can help clear mobs more quickly, reducing time spent per farming loop.
10. Optimize Rune Bursts with AoE Spells
For Intelligence builds, spells like Comet Azur or Adula’s Moonblade can wipe out groups efficiently. Properly specced mages are some of the fastest rune farmers in the game.
11. Know When to Buy Instead of Grind
Sometimes, it’s worth it to skip the farm altogether. Some players choose to buy Elden Ring runes online to get past difficult sections or test new builds. While not everyone’s cup of tea, it’s a legitimate option that saves time for those more focused on exploration and boss fights.
12. Revisit Volcano Manor for Repeated Farming
The enemies around Volcano Manor — especially the man-serpents — offer solid rune rewards and can be taken down fairly quickly with fire or strike damage. This is a lesser-known farm spot with high output.
13. Pick the Right Gear From the Start
Choosing the right build and investing early in rune efficiency pays off long-term. Players often overlook how much time they can save by getting the correct items and talismans early. If you're short on time or builds, the best place to buy Elden Ring items might just be from reliable in-game vendors or curated external shops — again, it's about time efficiency, not just tradition.
Whether you're aiming to hit a higher level for PvP, preparing for New Game Plus, or just trying to beat that one infuriating boss, farming runes doesn’t have to be a chore. Use these tricks to turn the process into a smooth, quick ritual that supports your actual goals in Elden Ring. As always, experiment with what works best for your playstyle, and don’t be afraid to take the faster route when needed.
